BigRailNut
In my basement, I have a nice little layout that my Father and I had been building before he passed away in 2003, and since then I have been trying to figure out exactly how he had planned on wiring it. I did most all of the soldering work under the table, and all the feeders are run to terminal strips along the bechwork behind the panel. He had a wiring diagram from the issue of Model Railroader that we took the plans from, and it shows a common rail scheme with SPDT switches used for block control. My question really is, can I simply run a single wire from each appropriate terminal to the SPDT switch, and then a wire to the terminal that will be connected to the throttle?....I only have 5-6 blocks that need to be wired. The layout is small, about 5 X 10 and there's lots of room underneath to work. I just want to avoid having too many problems since this was'nt my original plan for this layout....
Thanks....
Thanks....
