Paul, not sure what you mean by a test board but, if both locomotives have decoders, the most likely address is "03" or the locomotive number if it's used. It sounds like the Athearn has a DCC ready board but no decoder, correct? If so, "00" should make it run since it's still a DCC engine. The "dn d" on the Zephyr doesn't mean you have on open circuit in the locomotive. It means the Zephyr isn't seing any current back from the decoder. This could be because you don't have it set to "Page" mode or you are trying to read back a CV from the main track, not a programming track. If you have a programming track set up, the Lenz and Bachmann decoders usually require a higher current to read back CV's. If this is the case, you can simply use the "OPS" mode on your layout and program a new address for the locomotive. Try a two digit address with the last two numbers of the engine. This should bring the engine to life. It's rare, although not unheard of, to have a new DCC equipped engine with a bad decoder. Rememeber, thought, that engine won't move or do anything else while the Zephyr is in Page mode and the engine is on an isolated programming track. You have to hook up the Zephyr to your main track to have the engine run.
