I finaly made the floor plan of my new train room. I want to have a layout focused on mainline operation, ex.: giving priority to passenger over a freight, traffic management and the like. I have a few ideas but i lack the experience to make an interesting and realistic trackplan containing the following:
-2 passenger station
-1 or 2 undertable hidden staging to keep unused train assembled
-1 yard (for showing off and do a little switching)
-Mainline should be able to continuous running with the removable bridge(see plan)
I model modern equipment, HO scale, so a minimum radius of 22" is mandatory, switches will also be NMRA standard #6 ( I make them myself with a fastrack jigs)
The room has electrical equipment in the back,so a small corridor is needed behind the layout, and a liftout section is needed to give a free acces to the breaker box. Because of this, the layout will be build on its own legs and will be able to be pulled further backward in case service is needed to the electrical equipment. the workbench area can be shortened by 2.5 feet, and the track can also go over it for a couple feet because the layout will be higher than the bench. I'd like if the yard was close to the workbench
Any help for the design would be GREATLY appreciated, from a little draft made on the corner of the table, to some CAD plan
