I have seen a few threads where someone painted/weathered their tracks and then needed to solder a joint or feed. I found myself in that situation and took a Q tip with a bit of acetone to remove the paint where I wanted to solder. Nail polish remover works fine too.
Acetone & nail polish remover is the same thing.
Yes but nail polish remover is weaker than pure acetone.
Is pure acetone easily available to the "common man"?
Ken, at most hardware, automotive and WalMart stores in the paint department.
Problem with only using a solvent is that you are basically thinning it and invariably some is left behind, albeit a thin layer. But in the wonderful world of electrical contacts a thin layer is just as bad as a thick layer.
After cleaning with a solvent, your final cleanings should be slightly abrasive to remove the film. A Bright Boy or masonite block should be sufficient once you’ve removed the bulk of the paint with a solvent.
You don't need much surface area. Just use the tip of a small screwdriver to scratch the surface. Takes 5 seconds.
Thanks. I used the wire wheel since I didn't have any acetone on hand, and while the top of the rail was bright (from a bright boy), all that spray paint was in the web of the rail, which can be harder to clean out.
I just dry the surface with a clean Q tip and haven't had a problem so far.
I clean my rail head with some cardboard soaked in paint thinner. It keeps me from accidentally rolling the thinner onto the sides of the rail.
