Hello everyone,
I am working on a science project with my daughter and I was hoping someone would be so kind to answer a few questions. Her project is to show different ways to generate power and my thought was to prove this by moving a model train. We will have several ways to generate power and the train in her diplay will move. This is all still in theory. I am thinking of a round track with locomotive and a couple of cars. Of course we are trying to do this relatively inexpensively.
My questions:
-Is N style the smallest trains size (we are restricted in display size)?
-DC voltage is used across the tracks to move the train (I have a hand crank that generates up to 8.5 DCv), correct?
-What is the threshold/minimum dc voltage to get a N style train moving?
Thanks in advance,
Jerry H
Well you can go Z scale that would be the smallest. the rest of the questions I really don't know.
Well, the maximum voltage for N scale is 12v DC.
N scale is more cost-effective for display, and the smallest circle you can make is 9.75 inch radius track.
8.5V will power the train at roughly 75% throttle, and use that as a benchmark of efficieny.
Minimum voltage depends solely on the locomotive. Usually the cheaper ones draw more current because it take more power to move their Ill-fitting parts.
IF you're wanting an inexpensive good running engine, look at Lifelike ProtoN. They don't draw much power and it'll cost you for $20-50 for a nice engine.
Minimum volatage could be as little as 1.5v (AA battery) you probably wouldn't move very fast obviously, because the voltage powering the rails like a rheostat works dimming your lights in your dining room for example.
Hope this helps. It's a good science project, and an interesting visual metaphor.
N scale is really about the smallest scale you'd want to use and it's plenty small enough for your purposes. As was mentioned, pay a little bit extra to get a decent engine with a low starting voltage. You can control the speed of the train with the hand crank generator in much the same way a power pack throttle works. For most N scale engines, 8.5 volts will move it along plenty fast. A good N scale engine will have a starting voltage hauling a few cars of somewhere around three volts. A poor quality engine might require 7 volts to get moving. Having an engine with less current draw will give you more ways to power the engine.
Jim mentioned current - what kind of amperage will the crank put out? An N scale engine won't need much current since the motor is small put supply power in the microamp and low milliamp range definitely won't be enough.
Mark
Thanks!
You have been alot of help. This information was what I was hoping to get.
I am not sure of the Amperage output yet, but I will check that.
I will be sure to post some pictures with the progress and end result.
Thanks for the input!
Jerry
Southern Railway lives on
