They work the same as Athearn Genesis I think... You have to remove the cover from the bottom of the trucks, then the side frames will slide off. The cover has pins that hold the side frames on. Be careful not to lose any gears or get dirt inside while the cover is off.
I'd skip the GP60 parts, and just buy new lights and use some window maker stuff to add the windows, maybe with some clear sheet behind it.
Why yes, but it will be FAR cheaper to improvise then pay a premium for parts you've lost or damaged!Please forgive my ignorance, but you can get new lights and number boards? I really hate to have this engine become parts.
Mac,
Were these missing parts described to you by the seller? If not, return it for a refund since it wasn't correctly described. If you knew these parts were misssing, it would have been prudent to find out if there were replacement parts available before ordering.
Why yes, but it will be FAR cheaper to improvise then pay a premium for parts you've lost or damaged!![]()
Its really up to you, but if its a P2K, Walthers is you're only real option. Life-like never sold parts to dealers.
Sounds good! Looks like you're going to have a pile of left over parts too.I should have read all my emails before I posted. The seller is sending me every window, light, and number board that he has that went to a P2K. Hopefully my parts are in there.
