NYO&W
The LIRR MP-54 Project:
This is my first attempt at building a kit in N Scale. The prototype was used on the long gone Whitestone Branch of the Long Island Railroad, a portion of which I will be modeling. Paint scheme will be PRR Tuscan Red with black roof and chassis. They were run as motorized coaches after electrification of the branch. I plan to scratch build the roof mounted headlight and marker lights, to represent the motorized version, prior to painting.
QUESTIONS:
What type/size mounting screw and pin vice drill bit/s would one use to mount the trucks? See photo for close-up of attach points.
Would I use a 00-90 with a #62 drill bit such as are used for Micro Train body mount couplers or something else? The kit manufacturer recommended a #1 screw, but what does that translate to in the screw selection found in the Walther’s catalogue?
I assume a larger hole would be required in the truck to allow the truck to pivot freely. How much wider should I go with that one?
Thanks for Looking!
QUESTIONS:
Thanks for Looking!
