Bob S
Well, here's where the "spare parts" came from for the Modernized MDC Mogul. This is the Model Power Mogul. It came with the arched window cab and cylinder saddle with piston valves installed, but I changed to the square window cab and cylinder saddle with slide valves. As such, the proportions are about perfect for the GBW saturated/slide valve moguls, although it is oversized by about 10%. C'est la vie. All I had to do is add the bunker extension, coal load and decals. The decals are prehistoric Northeast Decals ... thay are at least 20 years old, but they were in perfect condition. The tender herald is is on a .010" piece of clear acetate to simulate the bolt-on herald used on the prototype. The outline should be dashed, but oh, well ... can't find a "correct' N scale tender herald yet. The final weathering and misting with DullCoat has not been done yet; it's just sitting on my test track for function trials.
With a WRX reefer:
This worked out well, as 251 worked the Sturgeon bay end of the line through the 30's until at least 1940. It was the last slide-valve loco purchased by GBW.
Next project is No. 351, starting with Spectrum Consol.
Carry on!
Resp'y,
Bob S.
With a WRX reefer:
Carry on!
Resp'y,
Bob S.
