drew1125
If you ever work with hydrocal plaster, or plaster of paris, making castings, sculpting scenery, etc…You know that when you get done, you always have that bit of plaster that dries inn the bottom of the mixing bowl…I use a plastic container to mix plaster in, so I can just flex the container, break out the dry plaster, & go on & mix another batch…
Now about that dried stuff…you can either toss it, or what I like to do is save it in a can like this…
What I’ve found is that this stuff makes a great additional layer of texture to my scenery…
I pour a little into a bowl…
Then I stir in a little India Ink & alcohol wash…
Then I add a little earth-colored acrylic paint…
You can either dump it onto a piece of wax paper to let it dry, or go ahead & use it while it’s still wet…
Once you’ve added it to the scene, & mixed it with other scenic elements, it adds a nice layer of texture to your scenery…
