So after discussing what scale I should go within a previous post, And the fact that I find that I Struggle with coming up with a layout That I am happy with. I should start a new Post. So that I can get some help in designing a layout that I can be happy with. This will be long. If after you read it all and If your interested in Helping me. Please DM me.
Here is my room layout. With detailed measurments
So I do have 1 window I didn't show mostly because it is not important and is below the 13' on the diagram. But can be view blocked with a background.
I can go through the closet with track Already have an opening on the entrance door side of the closet. But would have to go through the closet door opening for the other entrance.
Update Edit
I am thinking of having 4-6 industries. - the entire layout will be a industrial spur of a shortline railroad.
Industries I like to consider,
Chemical company. with 3 tank car spots.
Small steel fabrication 1-2 bulk head flat cars occasionally (not switched often)
warehouse 3 Car spots of Box car. (already built)
Some kind of industry for covered hoppers. minimum of 1 to 3 car spots (maybe plastic pellets or dry chems)
Maybe a team track or transload.
Suggestions welcome.
Looking for a track plan that doesnt over crowd the layout, But still has some dead space.
UPDATE #3
Here is the layout I am currently Working on... Tips and suggestion, along with help planning would be greatly appreciated... (this may become a build thread) If i can finish the track plan.
So added details,
Here are my Details, I specifically want to model an industrial setting, Whether it be a Port or industrial or both.
I am thinking to model the 1980's-90's (My RR will be based on the Prototpyes of MD&DE and eastershore RR. both fallen flags)
However the location and industries can be freelanced. (just plan on Modeling flat wetlands.) I really like Neville Island industrial as insperation.
Layout will be a switching layout with optional continous run. ( the option for continues running can be a drop in section or hidden don't care.) Plan to operate it as a point to point. But still like to have a continues run on Occasion.
Largest locomotive I plan to Run is a SD40-2 and SD9s on rare instances, Most will be 4 axle alcos and Emds, rolling stock 60' is max I am willing to go.
No passenger coaches!!!!
I want a minimum radius on main line, 24" How ever industrial sidings Can be as low as 15. (as some industries have very tight curves) but primary 18"
DCC will be Primary. May wire for both DC and DCC. Don't know yet.
Do not need a Yard, But Not apposed to it either.
Since I can hide 1-2 track behind the entrance door I think it be a good place for stanging. entering the layout through the closet ended at the entrance door. But could always drop in a section for continous run when needed.
Some track plans I like But don't fully fit for me, Is Tom Klominski georgia Northeastern, and Tom Johnsons cass county.
Turnout size, I don't care. While I like to keep it as Prototypical, If I need to put in a snap switch to make it work. I think i can after ballasting and weathering and make it look like its not out of place.
Benchwork I am thinking 12"-18" shelf depth No more.
Center peninsula is an Option, But I would have to make it movable to move it out of way at times. But no turn back loop.
Benchwork height will be 50-55" give or take.
Having a Small Bridge scene while nice and if it can be fitted in. sure but Not important.
I will be the only Operator. I like a layout that can take 30 minutes to 3 hours to operate. But with health 1 hour be more within reason.
Hope you will help me with this journey...
Update Edit
UPDATE #3
So added details,
