Thanks all! Hopefully I'll be able to start the next phase next weekend (racing this upcoming one).
Also, I would just glue the roadbed (cork?) directly to the foam layer, no need for plaster unless your making mountains. (That's what I did at least.)
Let's see some progress pics Ian.
I'm leaning towards the Woodland Scenics foam roadbed. I really like this new layout (thanks for all the help and suggestions Michael!), but I really need to get to the point where I'm installing switch machines to really enjoy the variety. Here is the track laid, and some of the buildings in place so I have some idea as to how things are going to lay out:
Southern leg, my DPM Coal River Station Gold kit (enroute) will go along the right side, with the coal loader going on the inside track. I plan on a mountain with a tunnel around the end, with access from the side, for the mine "bridge" to tie into:
Here is the Eastern leg, I was really worried that I wouldn't be able to fit the Walthers Modern Roundhouse (the size really took me by surprise), but it fit just fine:
Here is one of the problem areas that lead to this thread:
And a couple more of my nearly complete roundhouse. Just finishing up the lighting and the track inside, then it will be complete:
So, like I mentioned earlier, I think my next step is to do the roadbed, then to start working on the switch machines. I will have some paired turnouts controlled by one machine (4 pairs I think), but that still leaves me with 18ish switch machines to purchase, install, then wire to the LED switch panel floating in my brain.
