Some 15 years ago I purchased a Lenz100 set and after setting up a small test track ran it for a short time and had to pack it away due to a relocation.
I now have the opportunity to use the DCC set on my much anticipated layout.
Unfortunately when I connect the LZV100Command/Power Station to a 16v 5amp power supply, the same used before on test, the LZV100 now just flashes the LED in slow mode.
I have checked my first section of the layout with a multimeter to ensure no short circuit and I have disconnected the connection to the bus wires, but still a slow flashing LED.
I removed the front panel off the LZV100 for a visual inspection and all looks normal,but do I see a large diameter button battery on the top pcb (the pcb I didn't slide out) and could that be flat and maybe creating the problem ? If that is so, is this something I can access and replace ?
Otherwise, what do I do to recommission my long mothballed LZV100 please?
Any help will be appreciated,thank you
