5050 strip
I ordered a 5050 version of these strips. I finally arrived.
I failed to notice the one I ordered was only a 30LED/meter. This strip was $18 delivered which I though was a good buy. The 3528 was $14 delivered. The 3528 strips I had are 60LED's/meter.
Anyway, here are the tests I did between the two types.
Differences from the 3528;
1. Wider strip,
2. Four conductor bus as opposed to two conductor (4 solder connections between each section),
3. Tri-color SMD's with separate red, green & blue LED's within,
4. Individual resistors (150 ohm) for each SMD instead of one per "3 pack".
You now have the option to run all three or any combination with additional circuitry, one of those optional controllers or something of your design by simply using different resistors or some type of rheostat design to vary the resistance (voltage) to each color to change the color temperature.
I retested current and then tested light output using a light meter set to a Lux scale measured three feet from each strip laying on the floor (easier to do it that way). I made numerous tests. (Due to the 3 amp limitation of my bench supply, I couldn't test voltage greater than 15.5 for the 5050 strip.)
5050 voltage & current:
12.0v - 1.6A - 35 lux
13.8v - 2.5A - 47 lux
15.5v - 3.2A - 55 lux
3528 voltage & current;
12.0v - 1.0A - 31 lux
13.8v - 1.5A - 44 lux
15.5v - 2.0A - 53 lux
18.0v - 2.8A - 65 lux
I would not recommend running much above 13.8 volts. I only tried 18 volts to see what the difference was. I measured temperatures over 100 degrees after less than 10 minutes.
