Kitbash Long Shark BP-20, and a B-unit for DL-109
I've mentioned these two projects in several postings scattered throughout the forum, but I thought I would bring them together in one single subject thread,...and particularly since I intend to utilize the same chassis for both projects.
Two Projects Utilizing
Proto 1K, DL-109 Locomotive frame/chassis
1) Creating a 'B-unit' or DL-110 for the SantaFe
There were several roads that had B-units for their DL-109 locomotives. I've chosen to model the Santa Fe one. I had to make a choice where I would cut the two shells such as to end up with a proper window placement, and a reasonable duplication in the roof details. I need to finish the diaphram on the one end and the coupler mount.
Then it needs to be painted and decals added.
2) Creating a 'plastic model' of the PRR, BP-20 Shark
I've always wanted one of these extra-long Sharks that PRR had...only ? of them as far as I know. So likely you will never see them modeled in plastic in a production manner.
The few attempts to provide a model for this BP20 never had a chassis of the proper wheel base. I've chosen the Proto DL 109 chassis. It has the proper trucks, and it has great weight and running qualities....even good speaker locations for a sound version. Had to do a bit of filing to get the shells to fit over the nose.
