Kato F40PH parts...a rant
ICG/SOU
HO & O (3-rail) trainman
Grrr. Today I finally got a hold of a TSU-KT1000 (Tsunami board for a Kato F40PH--easiest sound install EVER), and decided to go ahead and finish the detail parts installation.
Included are 4 numberboards (only need two), 2 Sinclair antennas (only need one), 20 MU hoses (only need 12...they should have been done in clusters because they are a pain for me individually), but 1 set of windshield wipers. Two wipers per window, two windows, so 4 total (2 are for the outside edge and aren't interchangeable).
I launched the first one into outer space when using the tweezers and the tweezers slipped. The second I lost about 20 minutes later. I cannot find them anywhere.
But, there are no spares. I don't know what I will do with 2 more numberboards or 20 MU hoses (will buy some DA ones, I think), and I can use the extra Sinclair on another locomotive, but some of the smallest parts (the windshield wipers) have no extras. Annoying.
ETA: Awesome. Kato is out of this exact part. I guess I'm not the first one to do such.
I've often thought about building an enclosed box to work on the tiny details. Sort of like a paint booth. A white inside surface with a light in the top. With the smallest front opening I could still work through. Then when I launch the tiny parts I will have at least a small chance of finding them again.
I have a large apron that I use w/a strap around my neck & the bottom I spread out & attach to the top of my workbench(at the edge). Or you can attach to the legs of the bench if it's not to big. That catches a lot of parts dropping. I also try to keep the floor cleaned just before I do a lot of intricate loco work & before I clean a floor around my bench I scan it w/a magnet. It's surprising what a magnet will pickup even after you clean a floor.
A large box about the size of a TV would be a great idea. A small fluorescent lite in the top & a small exhause fan on the side. Cut the flap on the front of the box to about 4" w/a magnet laying just inside the front.
Isn't it amazing how far a part can travel with just the right amount of pressure? Coupler parts "spring" to mind.
I feel your pain.
I sometimes use a similar apron to Larry, it does catch a lot of MIA parts.
On a similar note, the other day I pulled out a track spike with needle nosed pliers. Again with just the right amount of pressure it took off like rocket and imbedded itself right between my eyes!
i usually end up with parts flying off my table cause 2 of my cats like the sound they make when they start shuffling them around. Mainly the heavier stuff like snow plows and side frames. I'll here a slight shuffle and then see it go flying as the cat slapped it off the table. LOL.
My workspace isn't ideal, but I'm usually pretty careful. Kadee coupler springs often are never found, but rarely to I launch one out in the first try. I added some grab irons to a Walthers high cube boxcar the other day, and it was easy to drop a few, but a sweep with a magnetized screwdriver and I could easily get them off the floor.
These windshield wipers are just a hair too small for me to handle comfortably. I've never been good with the itty bitty parts anyway.
I can only imagine how many lost kadee springs are on my layout's carpeted floor. i should just vacuum and i could find some interesting parts in the bag.
