rbwhale
I'm starting a 84" by 40" N scale layout. Due to our small house the layout will have to be folded up against my study wall when not being run. I'll be using Kato Unitrack. I know a common complaint is the plasticky, joint obvious character of the track, but I am reluctant to try the traditional glue/ballast route because if some of it falls off every time I raise the layout, it will cause a mess and eventually get everywhere, probably including the turnouts.
SO, if I do go the glue/ballast route is the ballast going to stick, rock hard when It goes vertical? If it will tend to flake off I'll simply weather and paint the Unitrack. I know some of you may suggest flex track, but I just won't consider it. Long story, not relevant here.
I hope some of you experienced folks can give me some answers.
Thanks
Thanks
