I've been working on my layout on a plywood table and still have a couple of turnouts to buy/install. I plan to use flex track for some of the turns. What I'm finding is that the flex track wants to un-flex. When this happens tracks start to come apart, or I get kinks between sectional track.
Anyway, I think it's time to get my 2" foam base installed. Once the foam is on the table, I'd like to get the track set up and run trains to ensure good alignment, proper turn radius, etc. Once all is good, I'll mark the track location and remove it to install roadbed, paint the foam, etc.
While running the trains, track on foam, but before ballast and glue, is it possible to "pin" the track to the foam so it doesn't move around? I was thinking about using some 2" trim nails (the type that come in sticks for nail guns), bend about 1/4" over at the top to hook onto the ties when the nail is pushed into the foam.
What do you think? Any other suggestions?
Thanks,
Doug
Thanks,
Doug
