Grade crossings for DCC
I don't see why they would not work.
The DS64 has the option to program as a crossing gate with whatever blink rate you want.
Do you know how I wire these up? Do they have connections to the track? Do they wire up directly to the DS64s?
Thanks,
Michael
They seem very simple to me. They do use track power as they need to recive the dcc packet code. The unit itself also does require a seperate power supply tho, cause it has capasitive discharge, but most likely you will not need this.
Programming them via cv's (just like loco decoders) is how you change them to work as blinkers and not switch machines
The digitrax website has the manual in PDF
if you have anyothet questions feel free to ask.
So do I wire them to the DS64 inputs? Same as a switch? And also to the track power?
Thanks kz9, I appreciate the help. I think I will go ahead and get a pair of these then. I already have some DS64s, and I saw in the manual where you program them for crossing signals.
Should be only 2 wires on the signals so ya 1234 ports.
LED's require resistors....
Those signal will work fine, as long as you don't use the Walthers crossing module controller. They are not compatible with DCC and will damage your DCC controller. The signals already have the appropriate resistors installed in-line with the wiring. Since you want to control them manually, you should only have to hook up the wires just like you were controlling a turnout.
