FS: Digikeijs Loconet Detection/Occupancy starter kit with 32 reporting points (DCC)
chadbag
I have a new DigiKeijs LocoNet starter kit with cables that includes a DR4088LN and a DR4088 unit and connecting cables. This allows 32 sections of your layout to report occupancy over LocoNet. I've decided to get the RailCom compatible version from Digikeijs and so am putting this up for sale. Has never been opened (except to lift the flap to check the contents) and the contents have never been removed.
Compatible with ANY Loconet based DCC system. (You do not need the Digikeijs command center)
Price is $90 and includes shipping inside the US. Additional shipping due for outside the US shipments.
Payment by check, money order, or PP friends/family
Manufacturer part number: DR4088LN-CS_BOX (2-rail)
Barcode: 8 718375 561171
Here is the factory description (as lifted from other sites):
LocoNet Complete Starter Kit with 32 reporting points
This feedback startkit with 32 integrated occupancy indicators is designed for monitoring 32 sections of track and is rated up to 3 Amps. The modules comprises four sections of 8 indication points, where each section has its own separate common. The network connections allow the modules to be placed up to 10 metres from each other.
The LocoNet connections make it particularly easy to connect the module to eg. your Loconet(r) system. 16 channels Power detection LocoNet connection Activity indicator LED Rated up to 3 Amps (peak) Standard S88 and STP connections (S88-N) Small solid housing by applying SMD techniques
* 32 Inputs
* Current detection (2-rail)
* 32 LocoNet connections
* Activity led
* Current load up to 3 Amps
* Peak current up to 10 Amps (briefly)
* Standard S88 and STP terminals (S88 N)
* Small solid enclosure by using SMD technology
(images are actual product I have for sale)
