I filed the Athearn F7 frame to fit included thinning the tab of the fuel tank so it would fit in the shell slots. I also filled the coupler pads and the two front frame tabs the shell rests on so they would clear the front cab steps other wise the frame would not move back far enough I also removed and re drilled the truck pins for the proper bolster to bolster length , used brass rod for the pins and super glue for a tight fit. . Installed a PK2 motor and flywheels from a GP30 in Athearn blomberg F7 trucks and drilled the frame for a ground screw from the motor. With the short flywheels and since Athearn don't fit I used the PK2 flywheel couplings and Athearn GP38-2 to the worms and Athearn ball ends like the flywheels on the worm shafts. I used the PK2 wheel sets replaced the 4 axle gears and soldered the top motor brass to each truck power arm. I also cut down a spare Athearn F7 super weight so it would clear the more round roof as well as the 4 roof fans which set down inside. Had some Accu Flex SP lark dark gray perfect match for the NYC paint the shell had factory to touch up a few spots. I have the port hole glass out since it hits the weight so I need to thin them down somehow or do without , it has the windshield and number boards and cab side windows installed just need to make hand rails all around where they go. I never know PK2 wheel sets were 39" guess 40" measured with a HO scale ruler at least on the GP30. Athearn are 42" Never checked before. It runs pretty good with this motor and drive couplings.
I'll post photo's if anyone is interested.
