Flex Track Question
eohdtech
Looking for a few options for joing HO Flex Track. I seem to be having troubles where the track joins on curves, I cant get a nice even joint, makes my engines and cars jump track. I tried soldering the tracks but thats not really working the best, unless Im doing something wrong. Any ideas or tricks would be great! The picture is a little dark but you can see the curves.
yes solder the flex track before it is placed on the layout. Personaly I dont use flex below 22" radius for the issues that you speak of. I have 18" and 22" at home and use sectional.Operation is flawless, it blends in just fine and have no issues at the joints....
The two responders have stated that you should lay the flex lengths as tangent track, join them, and then solder them. Afterward you can flex them. That is correct.
But there's a bit more: First, you really can permanently bend flex track. Takes some doing, some courage, some practice....but you can wrap it around curved blocks of wood screwed to a working surface, held down so that it won't flip up on edge, and bend it permanently. That helps.
Secondly, the ends won't bend....period. So a trick is to slide the sliding rail about four or five ties deep into the other length of flex, necessarily displacing that section's sliding rail by the same amount. Use a half-joiner there and solder it. The spike heads on all those ties will help to bend the rail ends and it will make the non-joined non-sliding joint further back do 'better'.
Otherwise, with strong fingers, flex and bend the rail length ends yourself. It can be done, as can anything we put our minds to. But a bit of curvature will really make a difference.
Lastly, and this applies to every rail end, no matter if it is on a turnout or on lengths of track, for ends the factory cuts or that you make with rail nippers....file them. Take a small metal file and champher/bevel the tire running tops of the rails and also the flange faces. Attached is a diagramme showing what I mean. This is very important. It is even more important when your curves are tight and you have joints partway through them. Flanges in tight curves press against the flange faces on the outer rails, and they will find chinks and rough edges, or mis-aligned rail ends. So file 'em!! By doing this, you create mini-ramps or cams that the flanges scraping the flange faces will find much less obstructive.
-Crandell
There's an even better way, Crandell... :)
If there is a bend already put into in the flex track, there are no lateral forces to act on the soldered joint.
If you remove the free rail on a piece of flex track, pass it through a few offset screws on a wooden block, and then reinsert it back into the ties...
It holds a curve all by itself without any mounting at all just as if it was a piece of snap track! :)
This is a 10 inch radius curve...
...works like a charm! :)
Greg
thats a good idea greg... I gave up on flex with tight radius but may have to look at your idea if I build a new layout.
I can't take credit for the idea...
It came from the Brits who are the most astounding narrow gauge modelling masters. :)
When the flex track holds its preformed shape you can lay it just as if it was a 3 foot long piece of snap track. Minimum radii are no problem. You can even form back to back opposing curves in the same piece. Flex track will preform any radius down to a 6 inch curve if you have the engines and rolling stock that will handle them.
Greg
All of the above. I like to use Micro Egineering flex on curves because it is not as springy as Atlas. I also like RibbonRail gauges at the rail joint to prevent kinks while soldering. Phil
