This actually turned out WAAAAAY better than I thought. I put some plaster of paris in wrinkled up foil and then stuck it to the side of some built up foam. Then used several colors of acrylic paints and finally dry brushing some white on it. Pretty good.
The only problem I have is that the base is an indoor paint. The acrylic paints would not stick to it for some reason. They did sit in the cracks for the most part but not much stuck to the main surfaces.
