Fascia-Mounted Car Card Holders
IronBeltKen
Lazy Daydreamer
Hi all,
I'm trying to get into using car cards + waybills. Printing them up was the easy part; now I need to figure out what to do for the pockets that hold the cards on the fascia during op sessions.
I tried browsing the Staples online catalog but didn't see anything there that wasn't overpriced. If I could find enough sheet styrene I could probably make my own, but I don't know where to find it other than the high-priced Evergreen stuff at the LHS. All I need is a bunch of little plastic** pockets ~3" wide, 3" tall and a half-inch deep. There must be something out there I can use as a basis for making ~60 of these things, but my imagination's running dry at the moment. Any ideas?
** -or any durable material other than cardboard
1/8" thick Plexi glass, table top scroll saw, and some weld-on glue! what ever you use your going to have to make it tough to hold up to being bumped in to and crap snaging them! Myself I would make um out of Plexi......... I'm use to working with poly carbs... so, Plexi would look sharp if done right! How many do you need? Plxi should run around $6-8 a SQFT.
I'm building mine out of 1/4" x 1" pine wood and a front cover of 1/4" thick Masonite hardboard. Gluing and nailing it together. That way I can make them any size I want! Just a thought.
Thank you all for the replies, gents!
Of all the ideas I read, I'll most likely go with Jim's and get the business card pockets. I need ~ 50 of them, and this approach doesn't require me to do any cutting. However, I would drill holes and use screws to mount them rather than relying on the self-stick pads.
Well not exactly car cards, but I used these business card holders from Staples with the stand cut down for my defect cards and incident reports.
I like those pockets too Jim, and the other ideas, may need those when I go the car card route too!
In my local Borders, I found "Trading Card holders" Little plastic pockets for those card-thingies that kids swap between each other - they hold a car card, and keep it clean, and you can pop a waybill in there too
How many cards do they hold Ken?
They look like they'd be thinner than what I have.
We don't have that store around here, maybe I can find them elsewhere...
Well the good news is they arrived at my door this afternoon - next-day delivery, man thats fast! Bad news is, they're not what I thought they were. They're made of vinyl, and totally flat - can only fit 2 or 3 cards in there, max. So back to the drawing board...
Does anybody know whatever happened to Reed (or is it Reid) Plastics of Baltimore? I did a google search but only saw links to them in FL and CA. I need to find a place where I can get a 4x8 sheet of .030" styrene at a decent price. I hope I won't be forced to go the Evergreen route...
Hello all,
I decided to use particle board for my card slots. Went to my friendly neighborhood Home Depot and picked 2 2'x4' sheets. When I asked the HD table saw operator how much it would cost me to get more than 3 cuts, he said he wouldn't charge me since he was 'bored out of his head'. So I got him to cut me ~15 3-inch-wide, 4-foot strips. Spent most of the afternoon using my miter saw to make over 300 cuts so I could get all the correct-shaped pieces for 60 card slots. Now I've started assembling them. I had just finished my 4th one when I got called to supper.
Ken, that sounds like almost as much fun as Ray's cornfield. :eek: I'll bet they'll be plenty sturdy when you're done though.
