SW7's and 1200's are more similar then a 1200/1500. The 1000 & 1500 share similarities.
The basic differnce between the models is the Prime Mover used to power them...
Here's a great page:
http://yardlimit.railfan.net/emd/index.html
For lack of a better description I termed them 'wavy'. Point is MANY of these Proto switchers develop this wavy warp in the handrails along the body of the loco. And the grab irons on the Proto engines tend to warp as well.they aren't wavy... Unless they have warped or have bent.
For lack of a better description I termed them 'wavy'. Point is MANY of these Proto switchers develop this wavy warp in the handrails along the body of the loco. And the grap irons on the Proto engines tend to warp as well.
Is this true, the new railings are OK? I thought it was a heat thing with that particular plastic that LL was using?This happened on early runs, and examples turn up at swap meets/train shows to this day, but the newer runs are OK. I have several more recent Proto switchers, and the railings are fine.
I have an original L-L SW-8/9 that has been sitting on a shelf in my air conditioned office for the last two years, waiting to get worked on. The side handrails started out as slightly wavy and now look like a rough day on the Atlantic.The really weird part of this is that it only seemed to affect the straight side handrails of EMD switchers.
This appears to be two conflicting statementsEspeefan said:It does not happen to the models after you buy them. It may have been the plastic, or a tooling issue, but they're over that hump, whatever it was
