I am sure this subject is pretty common but I'll ask anyway.
In designing a layout from the ground up around DCC - what is the best way to control tunouts?
I realize the wiring of the points and frogs is a consideration, but my question more pertains to the control. I understand the circuitry side of the wiring OK.
Carrying on that thought, a large layout I have seen, from what I know - converted over to use DCC, has custom switches run with Digitrax DCC. I don't know what the actual motors are, but they are under the table. The turnouts appear to be Atlas 2750 and 2751's.
What I do like about the 2750's and 2751's is they are basic on top = there isn't a solenoid or other bulky attachment to the turnout on the layout, it is all concealed under the table.
Though, that isn't a real important factor for me - the above table "stuff" - just an observation.
It looks like the standard remote Atlas switches are 3 wire designs - 2700/2701 models. If I ran that I would have to have an additional decoder, such as the NCE Q-Snap (quad switches) or Snap-It (single switch).
If I run some kind of custom switch that gives me more options for an auxiliary control mechanism/motor (tortoise, servo, solenoid). That might be more complicated than I want to do with it, though.
It also doesn't look like there is a cheap way to do this. With a Snap-It and an Atlas remote switch I am at around $40-50 per turn out. On a layout with approaching 20 turn outs, not including yard and staging, thats a lot of $!
