How does DCC work: does the controller send a message to the decoder, which then remembers the last command, or, does the controller keep sending its message and the decoder reads the frames addressed to it?
Put practically: what happens if you have a train running on loop at constant speed until it encounters a section of track isolated from the rest of the track unless momentarily energized with the same signal that the train had been receiving before entering the dead track? Will the train start rolling again? Or will it wait for a new "go" command?
I would like two track run through staging reducing to single track mainline on the visible portion of the layout. It would be cool to be able to put a short section of isolated track on each of the staging exit tracks so that a train will hold up before entering the single track visible mainline until it receives authorization to proceed.
