Code 80 #6 Custom or Standard Switches. Is there a difference?
John31874
I have picked up a set of plans (for RTS) from the net and not done much modification at all. I have printed out the list of items needed (all Atlas Code 80), but have come across this: My list calls for (Part# 2751) #6 Custom N Line Right switches. I would like to use remote switches. I have placed the #6 Remote Turnout Switch right on tip of the custom switch, and see no difference in the software. I also see that there is a standard #6 manual switch right that also appears to be the same size. I can see a manual and removte version of the standard being the same, but the 'custom' is confusing. Is there any reason I could not swap one for the other?
All three types of Atlas #6 switches can be substituted for each other. The reason for the three types is as follows:
Manual - includes the attached switch machine minus the coils. This allows for manual activation but not remote activation.
Remote - includes the complete attached switched machine. This allows for manual or remote activation.
Custom - Does not include any switch machine at all. They are called "custom" because you have to add a method of throwing the turnout. This is the type you would use if you wanted undertable mounted switch machines.
Thanks! I have order most of the track that I need, and also a couple of books to help me along. I've decided not to order all of the track until the books come in. With questions like the one you just answered, it looks like I need to do a little more research before dropping to much $$ on things I may not want/need.
I will wait untill I can read about under table switching before making a decision on what swithes to buy. The table top remotes look a little un realistic to me. Not sure how I would 'blend' these in to look natural.
Yeah, the Atlas switch machines are a bit difficult to explain, except in tunnels/staging where looks don't count for much. If you find switch machines to be a bit over complicated you can always use ground throws. I've got a couple Caboose industries throws, which seem to work, but are a bit on the large side. They'll hook up to an Atlas switch with little to no modification.
