Battery Car
gabby
Bob Hayes
Am converting an Aristo Box car to bty power. Am using Atisto's Btys (CRE-55610).
Is there any problem if I use 2 btys connected with their CRE-55611) Y adaptor. My knowledge is limited with this sort of thing and I am presuming that I will get a longer run time with the 2 btys.
Gabby
as long as the batteries are connected in PARALLEL, you will get 2x the life.
If they are connected in SERIES, you will get 2x the VOLTAGE, and THAT would be very bad for whatever you are powering with them.
If this sounds confusing, post a link to where I can look at this Y adaptor and I can translate it for you unless a better expert comes along that knows directly.
Kenw thank you. I have a pack here with the adaptor and the label says it is for using 2 btys in parallel so I am presuming it should work. Have taken some photos and will post them later on today
