Trussrod
Curious to see what you guys have done with your Atlas turntables to weather or enhance them?
Also, I ordered the 305 model which has code 83 rail I'm fairly certain and may try to replace it with code 70 or even 55 if that isn't too much work?
Have any of you modified your in a similar way?
Also does using lighter weight rail require recessing the unit a little deeper for the rails to match up?
Your input is appreciated.
