Dan
Hi all, I have an Atlas GP38 which I am in the process of a heavy kitbash to GP39-2,
Its a silver series which means it has a factory equipped decoder.
It will be equipped with ditchlights, my online research seems to indicate that surface mount 0.8mm Golden White LEDS might do the trick, I understand one disadvantage with LEDS is not being able to get them to flash on/off but using micro bulbs can present heat problems, any opinions on this anyone?
Also while I have the shell in a million pieces I do not know if the headlights as they are, will be up to scratch, I am wondering if I should be looking at wiring in new/replacement leds or bulbs directly behind the headlight/numberboard rather then relying on the facory 'tube' system, I would appreciate any experts out there passing on their thoughts/knowledge on the matter.
Dan
Dan
