MilwRoader_Steve
I know, a stupid question:
Walthers New turntables. They give a range of power supplies in either VAC or VDC. That, I'm okay with. They want 250ma, I assume that is a max?
So, Can I power this from a 18VDC common supply that is rated for 3+ amps? I'm also putting in some Kadee electromagnet decouplers, and they need 18 VDC and 3A. I doubt I would run both the TT and the decoupler at the same time, but what if I did? Can I connect both loads to a power supply that is rated for 18 VDC and 3.33 A?
So bottom line question is this (and I think I know he answer, but would appreciate hearing it in plain-speak from someone more knowledgeable): If a load only draws 250ma, can I hook it to a source that provides significantly more than that?
