NYSW F45
Ok i went to tackle some painting today to get ready for the Northeast Fallen Flags proto meet in Ocotober. I wanted to touch up some of my PRR painted bi-levels and lay down 1 color of yellow on my SD90Mac. I used primer on both units as the tuscan wouldn't cover the prr buff well.
Primer went on fine on all pieces of equipment. First was the PRR tuscan, wasn't having any issues in the beginning. But towards the end it would start to spit/spatter spray. Thankfully i was pretty much done with that color. So I went inside, cleaned the bottle and airbrush with hot water and soap and an airbrush cleaner type brush. Cleaned the needle aswell.
Lastly I went to spray some yellow on my SD90Mac. From the moment i pulled the trigger I had nothing but problems. Only air would come out, then a faint mix of paint/air. Then no paint again. Started adjusting the needle...nothing. Take the tips apart thinking something is clogging it up....nothing. Then it started to spit/spatter spray the yellow. I was barely able to get a coat of yellow on the model.
What can I do to stop this issue from happening all the time?
The spitting/spatter spraying is the first issue.
Second issue is the yellow paint itself.
The sprayed the shell with primer and let it dry. Was about 40minutes between primer and yellow. Now with the yellow that is on the shell its like a very rough/powerdery feeling coat. The yellow just wont cover up the primer one bit. I had the same issue painting with white a few months back.
Should I be putting down a pre-yellow coat of silver maybe? Or did I just thin the yellow down to much? No matter how much i keep spraying the shell the yellow will not cover properly and will be patchy.
